youll get better scores if you do.AZN said:ah thx guyz, i thought i was working but had to be sure. i guess u dont ahve to reformat like some people said![]()
Even if it says 50%, a single-threaded program is using all of the resources that it can. Like others have said, running two instances of something will bring you up to ~100%, but that doesn't mean you'll be getting twice the throughput -- it's usually about 0-20% more.
dustybyrd said:
that depends on the program...i think if you run two instances of prime95 on a dual system you get two prime95 programs running at nearly the same speed...
Yeah running two instances of Prime for stability testing won't help anything (though it won't hurt anything either). But if you have a burn-in program that does a lot of integer stuff (e.g. BurnMMX or Sandra), running it at the same time as Prime might cram more tests through the chip.
