Ok... if you want hyperthreading we got cheap motherboards and a damn expensive cpu to go with it (the 3.06GHz p4) or expensive motherboards and some more resonable priced cpu's (p4 xeon... at least the 512kB ones up to 2.4GHz). Intel made two form factors for (basically) the same cpu, s478 and s603, so that we wouldn't use the cheaper s478 cpu's in dual configuration, but that's not what I want to do... Making s603 to s478 converter should be possible, with this being basically the same cpu, shouldn't it? Though this isn't a straigth forward mod... I would need some parts and the knowledge (hehe...
What do you think, running a s603 cpu on a s478 motherboard, is it possible?
Powerleap and others... where are you? Give me what I want... now! hehe
Not even sure if it's even worth it... if possible...
ah well... just something I had on my mind.
