Hyperthreading worth the extra cost?
JML
Senior Member
New Jersey
I've been looking at a 2500+ Barton (a mere $90 on newegg) vs a 2.6c P4 ($170, almost double the price of the Barton).
Is the hyperthreading noticeable in every day applications and general windows use?
no :p I see no difference, the apps I run are internet, games, music, e-mail, and occasional video editing. In fact with win 2k I see it being faster with it turned off :-/, however If you have XP it should work fine even on Home because that is the os it was made for.
i heard with video editing and stuff, some people say they saw up to 30% speed increase... it really depends on what your doing.
Doesn't seem like it's really worth the extra $80. Guess I'll stick with AMD :)
It really depends on what you use your computer for. If you're just using it for browsing and occasionally gaming then I doubt you'll notice the difference. If you do a lot of video/sound editing or folding then yes it would be worth it IMO. :)
Who would try to encode a video while playing a game anyway? Its nice that you can but...it just seems like I'd be doing a half assed job of both of them.
are you planing on buying all new components?
-if not
what components are you planing on keeping?
Thinkin about it as a xmas present. I'm not sure what board I want, though I'd like it to have SATA RAID (can windows boot from a SATA RAID set-up?), and have a 400FSB. To go w/ the mobo, Corsair XMS PC3200 512MB ram, and maybe two of those new WD 10,000 RPM SATA drives >=-)
There's prob some other crap I want I can't think of at the moment cause I'm exhausted. I'd appreciate motherboard suggestions though
Whos looking @ zabomb's sig when you can look at his avatar :p
Anyways ... I think he means the 8RDA+ ... 240 is good cept the 7 multiplier :(
I got my 2.4C --> 3.1Ghz 100% stable on stock cooling.
