- Sep 5, 2002
- Boise, ID
Summary: I was desperately trying to fit all my watercooling components in my case and have been de-attaching the tubing and re-attaching it constantly.
After about half an hour or so, I turned on the computer only to see my display completely garbled up.
I knew instantly that the problem was with the graphics card but I was really puzzled as I hadn't modded the card at all!
A couple seconds later, it all became clear. To my shock and horror, I saw water *DRIPPING* on the Radeon 9700 PRO!!!! The tubing finally had enough of me it seemed.
At that moment, I had 2 choices. I could either run to the bathroom or turn the computer off immediatly. I went for the second option.
Covered with sweat all over, I took the card out of the computer and ran to the bathroom! NOT TO TAKE A CRAP THOUGH!!! I put the card on one of the towels in the bathroom and gently pressed on it so that the towel sucked up the water. The card was literally soaked so I had to take a bit of time to dry it.
In my panic, after convincing myself that I had totally dried the card, I sticked it in my P3 to see what would happen.
To my ***GREAT RELIEF*** the display wasn't corrupted and everything looked fine. I am now typing on my P3 and no problems so far. I was using pure distilled water and thank god for that but I knew that once the water hit the tubes, it wasn't really totally non-conductive anymore so I was scared ****less.
In the end, the card works fine and I managed not to crap my pants but it was close...
