I know it is overkill as long as I don't buy a new monitor. But howmany resolution steps are between 1280x1024 and 1680x1050?
I could view it from 2 angles, buy a videocard which handles 1280x1024 very well with GOOD fps on that resolution, standard min. of 125fps in CoD5 or so. This will save me hopefully money.
Though, I might buy a monitor in the future and then I have a real good pc, instead of limiting everything to the monitor now. Because if I don't upgrade my monitor, I will buy an older / cheaper videocard, this will be my limiting factor then, so then I can also buy an older / cheaper motherboard and downgrade everything to my monitor settings. The bad consequence is that the system will get sooner outdated.
My suggestion: Play with 1280x1024 though its overkill now, I know I have a system which can get along quite a time, and I can always buy the monitor later. If I would downgrade my stuff to the monitor, that would be stupid because I would get an outdated system sooner and need to spend a lot of money in a shorter amount of time.
Am I correct guys?
Is my argument coherent and solid?
