i cant believe it booted!!!
fiji
berlin
yay just finished putting my cpu together it boots fine, no beeps or anything woot :) :)
just gotta clear the cmos i think it says i got a checksum error
then i gotta set up windows:(
ill post some pics in an hour or so
lol im up to my waist in peanuts, and electronic parts/screws
i just gotta thank you guys for telling me how to put it together, what parts i should choose etc, thanks guys
let see if i can still remember lol
ok 5 blue coolermaster 80mm led fans
1 enermax cpu fan
slk-800U
amd 2500 barton
abit nf7-s
sparkle 400watt psu
chieftec silver server case
52x48x52 cd-rw
floppy
80gb WD special edition
gf4 ti4200
sweet system man. How much ram? When I first built mine, I was totally shocked and suprised my booted up too! Were you nervous as hell when you hit the power switch? :D
oh damn i was shaking man i couldnt even hit the power button lol
i was expecting to here BEPP BEEP BEEP
but i was suprised lol
512mb ram
nice setup, im glad your first build went well. My first build was a tight budget from my dad to build my grandma a puter out of scraps. It didnt go so well, somehow the ECS k7s5a pinout didnt match the manual and in a last ditch effort a friend had me try random locations for the power switch. Im glad yours went well.
lol you should of seen me a few hours ago
i was opening up my box from newegg to find out that the only manual was the mobo one ... then i was like alright less for me to read eheh
then i find myself with 2 screws and a slk-800U saying WTF
it just wouldnt fit, it took me 1 and a half hours to put the damned heat-sink on
but when i booted up my idle temp was 32C so i think thats good right?
512mb ram
Heh, I know exactly how you feel. When I pressed my power button the first time, I got absolutely nothing. Turned out, I didn't connect the power switch right :rolleyes
When I got it working, words could not express my happiness :D
Congratulations on the new system, looks very nice!
32C is a good idle temp, but try letting it sit running for at least 10 minutes before reading the temp. It will probably climb considerably in first few minutes.
I think thats good. Idle temps for my ax-7 is around there. Could be a little better I think, but not bad at all. So, this is your first rig you have built, right?
right
If you havent let the cpu run for 10 minutes or so, the cpu temp will probably go up like 8-10. If you havent updated your bios it is probably reading 8-10 high. Either way, nice temp. I have a nf7-s and 2500 also. Stock hsf until I get everything set up. Runs at about 43 in bios, although I have a hot ambient temp.
right now im posting this on the comp i just built, all the drivers installed gunna go run some benches :)
you are lucky with that board! i had 3 dead nf2 boards in a row.
glad you are having fun. play some games, surf the web. enjoy your new rig. :)
its sweeet, even surfing the web is faster lol it loads so incredibly fast i really like it
i gotta find some drivers for my digi cam and a host then ill put the picitars on the interweb
right now its oced to 1900mhz at default voltage
temps are 38/39c load
29/30/31 system temp
32/33 idle temp
Ill be getting and putting my system together soon!!! :D
I hope it goes as smoothly even tho i fear the instalation of the cpu to mobo...lol thats the only thing..never done that lol...hope it goes as well and CONGRATS MAN..you got a kick *** system.
