- Apr 10, 2001
This is more research I did for my water cooling. I've been looking at the 120mm fan I'll need to attach to the radiator. I looked through Sunon's site and found specs on their fans. The part number that looks to be the perfect match is as follows:
KD1212PMB2-6A
Here are the specs: 120mm X 120mm X 38mm, 98CFM, 36.5 dBa, 5.1W, 2800RPM, 12V.
I've looked everywhere and can not find this fan!
I did find
KD1212PMB1-6A
It has specs of: 120X120X38, 108CFM, 42dBA, 6.8W, 3100RPM, 12V.
I thought for 5.5 dBA less and only a loss of 10CFM this would be the way to go. Anyone know where I can find these or something with similar specs? Both have the 4pin connector I believe.
Thanks in advance!
KD1212PMB2-6A
I did find
KD1212PMB1-6A
Thanks in advance!
