First of all, Hello: I've been reading through these forums for a couple months, but only now did I feel the need to post.
So, I did the Pop Can Block (you can find info about it at overclockers.com under watercooling), and I have to say I'm proud of it, since it's my first watercooling setup.
It's setup very simply, as i didn't by the heater core yet, so its just the waterblock with 2 pieces of tubing going to a small container of water wich also contains the pump (1000 l/h).
Anyways, with this setup, under load the water gets hot real quickly, but that's to be expected without a radiator of some sort. But just after bootup my CPU temps are around 32C, using water wich is much cooler than ambient. That seems a bit high to me, as water hasn't yet had time to heat up, so the missing radiator shouldn't make a difference. Or am I wrong?
The wb is lapped using 400 grit sanpaper, and I did it in 20 minutes, so maybe that's the problem. Or maybe it's because I'm not using artic silver. Anyone can tell me if my temps ought to be lower?
By the way, voltage is at default 1.75 (yes, it's willamette)
