I don't fold anymore.
dumpa
USA
It didn't work.
I used a GUI version and every time I had to shut it down to play a game. It would constantly go back to desktop.
It would freeze sometimes for no reason.
Also when using System Mechanic (if the program wasn't active) it would start folding from 0/400 (I would loose any data that was done previously)
Text version was fine, but I don't like that thing in my taskbar all the time.
Good luck guys!
KaHNZa
Senior Member
West Central MN
Thats sad to here. But I'm not going to try to convince you otherwise. Its your choice what you do with your computer. ;)
illwillchill
Seattle, WA
i use the no frills cmdline version and run a program called hideitx to hide the console completely, it only shows up in the system processes.
http://home.attbi.com/~wxdude1/emsite/hideitx.html
I have two desktop icons: one "Start Folding" and "Stop Folding" so when im about to play a game or something, i can quickly stop and restart folding quickly
add these commands to the shortcuts
shortcut command line for start folding
"C:\Program Files\[email protected]\HideItX.exe" -starthide c:\Program Files\[email protected]\FAH3Console.exe -advmethods -forceasm
for stop folding
"C:\Program Files\[email protected]\HideItX.exe" -stop c:\Program Files\[email protected]\FAH3Console.exe
I'm not sure if this will convince you to try folding again but it should help.
MrMarbles
New Jersey, US
Are you aware that you can hide that thing in your taskbar?
You can either use Electron Microsope or run [email protected] as a service (w/ win2k or xp).
Btw I had exact same problem with the graphical version. Now I use EM/text version and its fine.
Kendan
Senior Punk
Dark side of hell
All you need is trayit or use EM3 to hide it. You could even use the service install. The graphical version is buggy with some vid cards. I always recomend the text only client with trayit to put it in the tray or EM3 to monitor and hide it. I still use em3 but just to monitor my rigs:D I don't turn it off while I game either.
Here is the link to trayit: http://www.aoaforums.com/files/code.php?file=917
Here is the link to EM3:
http://home.attbi.com/~wxdude1/emsite/index.html
Here is the link to the service install:
http://forum.oc-forums.com/vb/showthread.php?s=&threadid=179298
The service install might be your best option:D If you need help setting it up just PM me and I will help thru PM/AIM/IRC
DeepScience
Super Kiwi
New Zealand
The only game there seems to be an issue with for me is WCIII. But that's only occasionally so I just alt tab out to squish folding for a while.
hmmm, I wondered y i was a bit slow. I managed to turn EM's command line thingy off. ok, advmethods back online :D
Tw00sh
Austin, TX
How
How do I make a stop command like that?
This is what I am using as a start up command:
"C:\Program Files\[email protected]\winFAH.exe" -advmethods -forceasm
I tried your line, but it does not work because I do not use the hideit program?
What should my stop command line be?
The VTech
Captain Bawls
Victoria's Secret
The GUI one also affects my Half-Life along with WCIII I'm switching over to the text version this AM when I get off work.
I kill it for that time and it's OK because...
I have a lightning fast PC at work running a PII 333MHz CPU on a PC66 FSB Intel AL440LX motherboard!!! It's beating out at 138/1250 at the moment! Woo Hoo! :D
PS this killer PC also is running an onboard Viper V330 4MB video card and 128MB of PC100 SDRAM. :D
Edit- twoosh, go to the url in the post for the shortcuts for starting and stopping. :D
OSUmaxx
Senior Member
Oregon
If that's really your only issue, just hide it with hideit or preferably EMIII. Very simple solution.
dumpa
dumpa
USA
I'm folding again :)
Thanks guys for your help.
I even played BF1942 with no problems :D
dumpa
dumpa
USA
All of them :D
Downloaded 3.24 text only version, installed EMI3, used .reg file, than used that setup.exe (service install) file, and finally TrayIt :D
Wedo
Senior Kitty Power!
Lost Angeles
Re: Re: I don't fold anymore.
nikhsub1 said:
Can you speak English? I don't have any idea what that means? :D
Translation:
Holdy $%#@! I want to fold but the $%#^ing thing keeps #$%@ing my #$%* computer. HELP!
/lavashly apply help here
"I'm folding again"
I love a happy ending.
Wedo
dumpa
dumpa
USA
Me neither :confused:
It must be a typo
Kendan
Senior Punk
Dark side of hell
dumpa said:
All of them :D
OMG
I hope you are just running one of them and you did the reg file after the service install:D with the service install you will see nothing at all and it will run even when logged out. The only way to tell it is running is to look in the task manager. Takea look in the task manager to make sure there arent multiple [email protected] clients running:D Good luck and FOLD on!!!
