- Nov 22, 2004
- Anchorage, AK
I just re-did my WC setup and put in my mcp-655 and the stifttech storm and my temps are the same as when I was using a modded mcp-350 and 6000 wb. I said well maybe I didn't mount the storm correctly so I remounted and there was no change. I am disappointed about the results. Could someone provide some insight as to what the heck is going on here?
I also just put 2 sunon 120*38mm fans on my BIX2 radiatior. I thought that would have made a difference alone.
Idle with 1.3v is about 30c
load 38
I cranked up the v to 1.55 +10% with no oc (was just checking temps and it shot up to 40+ on idle. I raise to fsb (dont remember to what) and load went up to 50+
I am pretty sure that that is the same if not worse than with my other equipment.
load 38
