- Oct 31, 2001
- Lost Angeles
The dually is finally finished after six months of reading, research, buying it piece by peice, and then finally, putting it all together. I want to sincerely thank everyone in this forum, especially CMC, for the questions, comments, and direction as to how to get this beast up and running, without this source the disgustingly fast gaming and home computing I enjoy now wouldn't have been possible.
As you can see in my sig, here's the nuts and bolts of it:
XP2500+ Bartons w/ L5 mod and a hard coded 15x multi (using the 5v psu method)
K7D Master
1.5GB ECC PC2100 Kingston DDR
Gainward Ti4800 SE
2 WD 10K SATA Raptor drives in RAID 0 w/ Promise RAID controller (thanks Nikhsub1)
Lite-On DVD/CD-RW Combo drive
Santa Cruz Sound Card
Polk 5.1 Digital Surround Speakers
Cheiftech Aluminum Server Chassis w/ TurboLink 420W psu
Case Mod to accept two lower-front intake fans (ala Dremel)
7 Coolermaster Neon fans
Windows XP Pro
I had more trouble with the lower front fan mod than anything else. After making a stencil, cutting, and driling holes, it was a little difficult to line up the fans. Blowing the last two L3's went suprisingly well and I only had to re-do one bridge as it didn't completely pop.
In the last two years I have built over 35 rigs for home, friends, family, and mostly, work. Let me tell you that the WD SATA Raptors are the hands down speed demons over anything I've ever thrown together. Adding the dual cpu's helped out too and the combo was able to install XP pro in under ten minutes!
Thanks again for all the help as this was my first real dually and my graduation from college present to myself so I wanted to do it up right.
Wedo
Here's the pics:
Here you can see the side by side dual intake fans.
K7D Master
Gainward Ti4800 SE
Windows XP Pro
Wedo
Here's the pics:
