I got a question,can someone help
jammw69
FL.
hi, i have a question about motherboards. i am getting ready to build me a new computer . i am looking for a cheap but reliable motherboard that i can overclock the cpu easily. i know cpu ,s are not really easy to overclock cause i have done it to a couple already. if u have any suggestions on the best to buy and any info on them please let me know. any ideas on cpu would be helpful also . what type of celeron cpu should i buy. thanks
funnyperson1
Senior Member
The Best Combo is the Celeron1.1A for 80$ and the Abit ST6 for 80$ for 160$ that combo will probably get you up to 1.5GHZ rock stable with a 15-20$ heatsink....
WELCOME TO THE FORUMS:p
PS: If you want a little higher end board the Shuttle and Gigabyte P4 boards are great for price/performance (60-80$) and a P41.6A will oc to like 2.4-2.5GHZ (180$)
takiwa
I agree w/ funnyperson1...the 1.1a and an ST6 will put you where you want to be. I got my Abit VH6T for a little cheaper than the ST6, so if money's real tight (like it was for me), that would be my second option...
and welcome to the forums!
jammw69
jammw69
FL.
I tried to find the mobo for sell on ebay. no luck on finding it though. do you know of a website that sells them by any chance. any help would be appreciated and thanks for the reply,s. all the computer stores where i live are ripoffs. they overcharge cause its a university town and locals take advantage of students. thanks
TC
Senior Seti Addict
Denver, CO
Try pricewatch.com for the best prices and stores that sell it.
jeeptuff
Arlington, WA.
I just got an Abit SA6R for $94 bucks delivered to my door. i sent you a PM with the guys address from whom I purchased the board from, he seems to have an abundence of Abit boards. Check your PM for his e-mail addie.. Hope it helps..:beer: :burn:
batboy
Senior Moment
Kansas, USA
For motherboards, newegg.com, mwave.com (multiwave), directron.com, or pui.com (power up) are all reputable online retails that I've done business with before that generally have good prices.
Yodums
Senior Member
Ottawa, Canada
If I remember correctly isn't that like a Coppermine ST6?
jammw69
jammw69
FL.
hey all thanks for the help. you guys have been great and gave me some really good places to try! :burn:
