- Oct 2, 2001
- Corona, CA
B/C Their are restiors in the way of the rubber washers to mount my waterblock so they lay flat. This causes 2 of the 4 vertical screws used to hold the W/B down to be not straight. So would this cause my W/B not to be mounted right? With a Large Un-known Dual 120mm heatercore, WW block, and qiet 1200 pump, on my expo 8dra+ I could get 35-37C full load at 2.5GHZ and 1.9voltcore. Now With my DFI at 2.0volt core and 2.6GHZ I get 46C idle and around 51C full load. This also mounted in my case. Its kinda ****ing me off. Rom temp is also about 85F and case open with temps around 35C. Any ideas to help me out on temps. Don't get me wrong, I don't mine B/C all fans are running really low 5-7volt and its quiet and stable as hell. It just makes me mad that all these people who get 35-36C full load and have a higher O/C than me.
