i have a ThermalTake XaserII 6000 and i need a new side Panel
TonyKlem
i need a new side panel i cannot find ANY sites with just the panel with a window and 1x 80mm fan hole except one in australia can anyone help??? with links maybe??
thanks
larva
Inactive Moderator
The Thermaltake cases are just another variant on the Antec/Chieftec theme (Chen Ming is the actual manufacturer of all these cases). You should be able to buy one of the pre-modded side panels for the Antec/Chieftec and use it on your case.
obliv
try www.directron.com, they sell them for like 8 bucks, even though they are steel, they are good, i have one on my aluminum case right now, i hated the original window that came with the case, so i took it off and modded it into what i have now.
