I have a Volcano 6 cu+, should I get a Volcano 7 cu+?
I suggest getting something else. Between 6cu+ and 7cu+ you probably won't get much.
Swifty
Alpha
AX-7
SLK-600
Heatpipe
All with "good" fans.
Cheers,
F
V7+
It seems like a good design(all coopper, thin fins, 70x70mm, 49cfm adjustable fan), and you can adjust the fan speed & noise with a switch. It's about $40, so cheaper than some of the heatsinks mentioned above. I'd say yes, but just because I'm curious about how well it performs.
