I have ordered many things, so excited! [re-build log]
SalemSaberhagen
Massachusetts,USA
6 x Alphacool G1/4 1/2" (13mm) Barbed Fitting with O-Ring "FatBoy" - Deep Black
7 x Alphacool G1/4 1/2" (13mm) 90 Revolvable Barbed Fitting with O-Ring - Black
1 x Alphacool NexXxoS ST30 Full Copper X-Flow 240mm Radiator
1 x Alphacool NexXxoS ST30 Full Copper 240mm Radiator
1 x Alphacool NexXxoS ST30 Full Copper 120mm Radiator
1 x Alphacool Eisbecher D5 250mm Reservoir - Acetal
1 x Aquacomputer D5 Pump Core | PWM Equipped
1 x Watercool HEATKILLER® IV PRO (INTEL processor) ACRYL
1 x BitFenix ALCHEMY 2.0 PSU CABLE KIT (red)
1 x PrimoFlex Advanced LRT Flexible Tubing (blood red)
1 x EK-FC1080 GTX FTW Backplate - Black
1 x EK-FC1080 GTX FTW - Acetal+Nickel
Total spent, way too much 767USD, thank god for a nice lotto hit.
GTXJackBauer
USA
Congrats on the lotto hit. (Wondering what you played and what the prize was. lol)
Sub'd to see what you have in store for us.
SalemSaberhagen
SalemSaberhagen
Massachusetts,USA
TY original build is pretty much here ... http://www.overclockers.com/forums/...t-enough-inputs-an-idea?p=7941895#post7941895
The waterblock will be the slowest shipper and ...
...D'oh, I'm short two connectors!
But everything should be here well before Halloween, being where I am it's a SpookyPC!
- - - Updated - - -
Oh and I play the masscash 100k lotto multiple times daily, at least a three for of the same number.
I hit for 750$ ... which means I got 750$ free and clear (3x250) ... sigh ,,, which also means I was one more match away from 300k or 210k after taxes.
Exhale, beer, dream about awesome rig, release.
I spent like 30$ more than I won, LOL
GTXJackBauer
USA
That's awesome to hear. I won $20 on a $2 scratch last month.
Now that you have the funds, I'm going to assume you've read the basics and maintenance involved already. Just making sure we're on the same page since I have no idea what custom water cooling knowledge one might have as many times they'll post about it and other times they won't because they don't. lol
SalemSaberhagen
SalemSaberhagen
Massachusetts,USA
Welp I once built a swiftech/bigwaterII horrid combo that ran awesome and didn't turn to a gunky horror show right away?
Since I tore that apart and went back to air I swore I would never try it again.
So the obvious next step was to order a bunch of stuff and dive in head first.
GTXJackBauer
USA
I'm a bit confused by your couple first comments. Are you saying you eventually ran into a issue?
The Bigwaters are a nightmare. I've seen my share of horror stories.
If you have any questions, please ask and read up. Don't be shy as there are no stupid questions as some refer too.
SalemSaberhagen
SalemSaberhagen
Massachusetts,USA
I read a ton and thanks for you concerns. I hope to publish a nice little build but as we all know that already has gone and will go wrong.
So catch up tomorrow as I order at least one more 1/4 barb ... opps.
Alos, I;ll have a lower percentage of ale.
Mistakes left intentionally ;)
GTXJackBauer
USA
My apologies. Didn't know this was your build log. If you'd like, go ahead and create another thread with the word "Build log" in it so others know.
SalemSaberhagen
SalemSaberhagen
Massachusetts,USA
This is my basic plan of attack, lets see where I end up.
Edit: Got the last three barbs, two to make it work and one extra.
Also picked up 6 extra rubber o-rings JIC.
Waiting on the GPU block and hose clips.
SalemSaberhagen
SalemSaberhagen
Massachusetts,USA
Just bought two gallons of distilled water, 6 pack of paper towels.
I'm scared.
Ugh, forgot a funnel!
Welp, two things have thwarted me before I began.
One, Ole Clunky the laptop wont start and while I was wrestling with that I was going over the steps of flushing and testing everything.
Flushing, yea.
I forgot a drain point. :(
SalemSaberhagen
SalemSaberhagen
Massachusetts,USA
Hah, these guys, I have an extra barb!
Welp, Mr Alcohol content says NO, not tonight.
Bro at work is having his wedding this weekend, so maybe next midweek.
Edit:
So, to finalize, I can leave one of the radiator or one of the gpu fittings with a "tail" since I ordered an extra barb (genius!) and simply block it off till I want to do the initial flush.
SalemSaberhagen
SalemSaberhagen
Massachusetts,USA
I've not been able to warm up to this "idea" so I will wait.
I think it's better to have some nice trustable mechanical checks in the loop to flush/test and fill.
So dear Alphacool, check will be in mail soon lol. I'm at about half as much into cooling as I am the build so I am not going to dive in.
...sorry if I'm a bore but ... ??? time money issues lol
SalemSaberhagen
SalemSaberhagen
Massachusetts,USA
So yea, a little update.
My TEE connector and valve show up this Friday.
Another thread here got me opening boxes and looking at how things will fit.
They will not!
The crossflow 240 is going to be a mess with the 120 rad and the reservoir is too tall for the space and may not fit with the front 240 at all.
LOL, so I did what any good overclocker should do, I opened my wallet again!
Phanteks Enthoo Pro Series PH-ES614P_BK Black Steel is on the way!
SalemSaberhagen
SalemSaberhagen
Massachusetts,USA
Case is here, OMG it's HUGE! :D
I think I could toss my Core2300 inside and shut the door!
I'm going to start tonight!
Edit:
Testing my potato getting ready watching the game.
Best of a dozen photos with as many settings, god this thing is crap.
