NeoGeo said:Yes, faster than a Radeon 9500 pro, based on the current reviews, although onced oc'd and a better driver is released, I think that the 9500 pro will beat such scores and a GF4 Ti4600.
Deadphishy said:thats a good overclock. i think i'm going to have to pick up a crystal orb when i get my 9000 pro back, and put my newely made ramsinks on it. my overclock was heat restricted so i could only get 310/606
asw7576 said:Nice OC maannn.... I wish my card can be overclock that high. You mentioned the use of 1K Ohm for voltage modification. Do you use the same value (1K ohm) for both GPU and Memory?
Do you know that when you use 1K ohm for memory, you are running around 4.08V for DDR? phew.... I hope the memory module is okay with such high voltage. Normally the DDR voltage for VGA card is around 3.30V.
Check out this picture to measure the voltage ( and how to overclock GF4 Ti4200 cards):
Or you may go to this thread for complete discussion on GF4 Ti4200 card modification:
http://www.xtremesystems.org/forums/showthread.php?s=&threadid=1045
Kato said:Nice
How much voltage are you feeding the GPU/MEM now? And did you use a 5k VR to mod them?
Man, soon I just have to force myself to Vmod too, heehee
Dirty_Punk said:my Abit Ti4200 with stock cooling did 335-340 (i don't know exactly because i hadn't tryed it a lot with aircooling ) for gpu & 650-660 for mem... this wihtout any mod
now without mod i run it with watercooling & 80w pelt at 360-365/670-675
this week if i'll have enought time i'll voltmod it
for now i have only 16k in 3dmark
Overclocker456 said:
Thanks. I'm using a OLD socket 370 cooler with a 25CFM low profile fan, I can't even hear it.
