itizme said:
What does this get us??
1) I see everyone still has fans within the case for airflow and the rad needs a fan so is it any quieter?
2) How much better is the cooling?
3) How much more can we overclock with water over air?
4) Why not use a much cleaner refridgeration system?
1) Yes, No and Maybe.
The two extreme ends of water cooling are Silence and Performance.
To get the absolute highest performance possible (without pelts or refrigeration) a water cooled pc may make as much noise as any other highly overclocked computer. And it is NOT a guarantee that you will get a higher oc: it merely raises the limit on how high the cooling will let you get. If the rest of the system bogs down @2100mhz, H2O will not get you to 2200.
The other end is Silence. Bigger fans make less noise (usually.) Even at default speeds or mild overclocks, a water cooled system can perform better than air cooling as far as noise is concerned.
Most of us are somewhere in between.
2) Well, that's really variable too: if you don't mind having a Tornado or 8000rpm delta next to your ear it may not be much better.....Modern High Performance air cooling does a great job and gets performance just shy of water cooling. In fact, the best air beats all but the best water cooling systems ON A STRAIGHT TEMP COMPARISON.
Hearing comes up as an issue again though!
Most water cooling systems are designed with the goal of having the best perfomance possible while maintaining low noise levels. H2O WILL beat air here.
3) Maybe none- chip/mobo limitations may be the problem. If temp is the issue then perhaps quite a bit: 200/400 mhz is not unrealistic with a good, oc-able system.
4) I have messed with refrigeration a bit (chiller not direct die) and there are a few reasons:
*cost- Water can be done for less than $100USD. You can buy all your stuff from a store and still get a decent system for less than $200 easily. Can't get a used Prommy or Vapo for that.
*Condensation- Preventing condensation becomes a huge issue with very low temps: the water is non-conductive but as soon as it comes into contact with a surface it will start picking up impurities which do make it conduct electricity. Keeping that from happening can be more work than you think.
* To refrigerate cheaply in any fashion means hme-built. THAT is a lot of work!
