ok guys i believe I HAVE A FIX!! i have been talking to a very knowledgable (thats a chance in a million lol) tech support guy from visiontek through email and i think we have this problem fixed! i am going to post all of my emai;s to and from him in thos epost..try and follow his instructions and remember the card MUST be on either IRQ 10 or 11 ALONE!
the first message was exactly how i started this thread as..
reply : I had the same issue once and it turn out to be that I was sharing the IRQ number for my video card with other devices. Make sure that is not the case. Let me know what you come up with. Jason
me: Thank you for the reply Jason i appreciate it, i was really expecting a "its not out problem; sorry" answer but i didn't get that, and for that i am impressed. i had checked the IRQ's and i am running windows XP Pro and according to the microsoft database XP likes to put more then one device on the same IRQ, it used to be that i had about 9 of my devices where all on irq 19! but according to microsoft that was not a problem..but after the format they are now spased out pretty well withought more then 2 on the same irq, i have attatched a jpeg with a screenshot of my irq's for you. i hope we can find a solution to this problem.
reply: How many processors does your PC have?
me: as in how many cpu's am i running in this computer? only 1...the P4 1.7@2ghz
reply: You have the video card on a virtual IRQ#. Our card need to be on IRQ10 or 11 by itself. Check to see which driver you are running in your Computer category in device manager. It most likely ACPI Uniprocessor which is the culprit. Attached is a screen shot of where the driver is. First try changing the driver to "Advanced Configuration Power Interface". See if that corrects the problem. If not you will have to change the driver to "Standard PC"(like I had to)lol. That will let your bios do the assigning of IRQ#s. Let me know how it works out. Jason
me: thank you for that reply jason! i changed it to Advanced Configuration Power Interface. and that didnt seem to work but then i changed it to Standard PC and it moved all my irq's around..but the graphics card is still sharing irq 12 with my firewire controller..however i decided for the hell of it to boot up tribes 2 and for the first time with this card it broke the 65fps barrier and actually hit 100fps! it still went as low as 45fps in crowded areas but the perfomance did increase! however the performance increase in flight simulator 2002 was only about 1-2fps..is there any other way to get that card on its own irq? thanks again!
reply: You may be able to change those setting in your Bios. Look for a section on PCI/PNP configuration. See if you have Pin assignments. Those pins are slots on the board in which you can specify IRQ#s. Otherwise, put the firewire card in a different slot. See if that changes it. Looks like we're moving forward though!! Jason
me: yup, went into the bios and i have PnP/PCI and i changed the video card onto irq 11 because you said it had to be on 10 or 11 and it was on 12..welp anywho now it is on 11 with 2 other things
i have attatched a screenshot of it,m anywho i am going to type out a layout of the bios screen for PnP/PCI for you it looked like this:
Force Update ESCD- Disabled
Resources Controlled by- Auto(ESCD)
PCI/VGA Palette Snoop- Disabled
Allocate IRC to VGA- Enabled
Allocate IRQ to USB- Enabled
PCI Latency Timer- 32 PCI Clocks
PIRQ_0 Use IRQ No.- and i set this one to 11 as this is the one for my video card
PIRQ_1 Use IRQ No.- Auto
PIRQ_2 Use IRQ No.- Auto
PIRQ_3 Use IRQ No.- Auto
reply: Try manually setting the other pin assignments to different IRQ#s. Try moving card around in their slots keeping the first and last slots open. I'm taking off for the day so I will be able to continue in the AM. I think you're almost there so keep at. Jason
so anywho what i did after that was change the rest of the PIRQ_1,2, and 3 from Auto to just a random irq but not 10 or 11 rebooted the vid card was on irq 10 all by itself booted up tribes and for the first time since i installed the card it broke past 65fps with all settings on as high as they go and hit 107fps! and never dropped below 49fps even in a huge crowd of people but it average about 75fps, flight simulator got a boost as well and Ghost Recon with everyhting on high never dropped below the mid 50's and averaged in the high 70's, i have not tested MOHAA yet but i am sure it got the boost as well..tell me if this helps you at all, i sure hope it does!!
