- Dec 21, 2000
- Salinas, Ca
As the subject says, yes i really did kill my 1ghz t-bird, when i was installing my alpha pep66t fan on it, the one edge kinda got scraped off. well my ? is i am not using that heatsink anymore so what heatsink would you recommend. i am scared of any heatsink made by alpha, so what heatsink would you guys recommend. one that hopefully has a really good track record for not killing cpu's. here's the other part, my case, a fong kai 6035 has a fan placement sucking hot air off the heatsink, howld i be able to flip any fan around so it is sucking as well and expect the same or ~ equal performance??
thanks
thanks
