I know "Go look it up!" What is the best slot one to 370 adapter?
Asus FC-PGA Slotket, Soltek FC-PGA slotket, IWill Slocket II, Abit Slotket III
The best are probably the Soltek and IWill units.
I recomend the asus s370-133 it an do all that the only problem is the stupid retention mechanism, I don't know what standard that is but it doesn't fit my board so you may have to use your brain a bit here, I took the clicps off mine and put some rubber tubing round the pcb to hold in in place on my board
Iwill Slocket II. Unfortunately I don't wanna risk my RMA replacement cC0 celly 566 in it as my old BH6 popped a Mosfet and killed the old CPU, whilst it was sitting in the Iwill.
The Abit Slocket!!! I am running at the moment, is holding me back at 95MHz (I think).
I am waiting for a Soltek.
dude (Feb 21, 2001 03:04 a.m.):
I want one that can support 66-133 FSB, gives a good range in voltage, and can support the new and old Celeron's.
I have an ABIT Slotket III with a Celeron 633@791. It works perfect on an ASUS P2B-F Slot1 mobo.
Look in the intel cpu listings for a post named "slocket question???" posted a few days ago. Good discussion of several models.
Mr B
