I have overclocked my A900 to 1110, and am running at 1.94V at the moment.
My CPU temp has been around the 42^C and the motherboard temp has been around 30^C, which i was very happy with.
However this was with the case cover off. As soon as i put the case on i got CPU temp in the range of 48+ and the CPU was no longer stable and i got some crashes.
So here is what i did, after reading some articles here i was inspired to do some case mods, i bought a 90mm and 80mm fan, and installed them in my case straight away but had limited success.
So out came the jig saw, i put on my butchers apron and went to work, the results where not pretty but i basically removed all the obstructions to air flow, to either fan.
I have the 90mm at the bottom front blowing in and the 80mm at the top back blowing out, I also cleaned up inside a bit to allow better air flow through.
Damm it worked better than i had hoped, CPU temp was 41^C and the board was at 22^C, the only problem is still the FOP-38 sounds like a jet taking off, so here my next idea:
Use a much larger fan that has lower RPM but still with the same cfm, fasten it to the side wall and use a funnel to direct it to the heat sink?
What do you all think?
Has anyone tried this?
