so i felt i improperly installed the heatsink on my i5 2500k, i didnt hear 4/4 clicks when pushing down the pins
i took the pins out, took out the heat sink, and put it back down (2 times because i messed up =/)
so basically the first time i took off the heat sink i saw a good circular imprint of the thermal paste both on the cpu and fan, but it was some what sloppy as it might produce air bubbles, but at the same time it was a nice circlular shape
anyways right now i reseated the heatsink with 4/4 clicks and i know its a solid connection, but im wondering if i should worry aobut the fact that i took off the heatsink and reseated it without messing with the paste, i did NOT power up so there was no heat to dry the paste, it was basically reseated 3 times in 1-2 minutes
i think i can still power up, install w7, check temps with hw monitor
but im still worried my temps will be off 5-10 degrees, i will def buy an aftermarket cooler and new paste if this is the case but what do you think, should i be fine (cant power up till i get my ram so im sitting here all stressed out)
sorry for this paranoid newb question but i spent a lot of money and i dont want to have to replace my parts because of a stupid mistake i made
