SOLVED i need an answer
R
Rich_dawg_71785
Guest
i have a stick of infineon memory and i dont no if it's pc 100 or pc 133, i'm not using it but just curious if it waz the problem y i couldn't get my T-bird to 1.4 stable.
the writing on the chip is:
hyb39s64800bt-7.5 then 0046 writtin verticaly
and then SEE 50254 smaller font on the bottom
thanks
-rich
R
Rich_dawg_71785
Guest
dum ***
and i care why? lol that didn't answer my question does any1 no?
takiwa
first off, welcome to the forums!!!
hyb39s64800bt-7.5
That little 7.5 at the end of those numbers means that you have a 7.5ns stick...
1000/7.5 = 133
So there you have it...it should be stable to 133...
