I need help before my CPU fry's!!!!
strokeside
Dublin, Ireland
OK, at first I thought I just had good cooling stup in my rig, but I overclocked my CPU by 24% yesterday, for which I had tro up the voltage, and the CPU temp only jumped by 1degree Celcius. Now I know the Alpha PEP66U is good, but not that good.
Doing the: (for non-overclocked)
C/W = delta/CPU wattage gives C/W = 5/30 = 0.1666
Which I know is not possible with this HSF.
I made sure the in-socket thermistor was in contact with the CPU, but it still gives a highest reading of 29.
Does anyone know a definite way to measure the CPU temp without resorting to buying and adding a thermistor between the CPU and HS?????
Anything?????
29 deg C is not going to fry your CPU. I am not familiar with the Abit Via boards, but Motherboard Monitor should be able to read the on-die thermistor and give you more accurate readings than the socket one. If 29 deg C is your idle temp, then under load you shouldn't see it rise much more than 5 or 6 deg C. I have a Celetin 1.2 @ 1.6 and at idle it's running about 35 deg C, under load it jumps to 39 deg C, but everything is stable and fast. I'm using a PAL6035 so the PEP66 is a better HS design, more overhead. I think you are OK.
it's ok, your chip isnt going to fry. the pep should keep a
celery 1.5ghz pretty cool, even if your probe is wack.
what are u using to measure temps, that is a reasonable temp for a 1.5 celle but still it "COULD" be a system temp, id double check to make sure.
My system temp never goes above 26 degrees celsius, even under full load for an hour.
The 29 is definitly the CPU temp. I do have a 60mm 38cfm fan on the alpha and two exhaust fans right beside it, so I guess it is possible that the HS is good and the temp. is true......isn't it?
To measure the temps, I am using the VIA hardware monitor program that came with the board, aswell as MBM5
