Hang on - your network will soar when it's hooked up to NETGEAR's FS605! This powerful plug-and-play switch connects at 10 or 100 Mbps and makes it easy to link as many as five computers or peripherals to your Ethernet network. You'll experience maximum performance for 10 or 100 Mbps devices with five ports that automatically sense the correct speed while Auto Uplink on the ports adjusts for the different types of Ethernet cables. The FS605's sleek case has lights on the front for easy monitoring. Installation into your home network couldn't be simpler and, once powered on, it begins cool and silent operation - without an internal fan.
This was the result of a 1 sec search in google.
So as long as you use cat5 cables it eats them all if you use a cross link it works etc....
try google before posting, it realy knows a lot
