- May 9, 2001
- Portland, OR
My last thread didn't help me much at all, so I'll change the situation around a little.
I'm looking for a case. The following conditions are nessecary:
If you own, or know of a case that meets these specifications, please post! I've been looking and looking, but Newegg and Directron's pictures don't clearly show some details. Sometimes there's only a single picture and it's only of the front, so nothing but the bezel's shape can be determined. Seeing as how I've checked back and forth through Newegg and Directron time and time again in a vain attempt to dig up information, I'm expecting that replys here will be from personal experiance--Newegg and Directron didn't provide me with the information I needed.
Brand doesn't matter.
PSU wattage doesn't matter.
"Tool-less" doesn't matter.
Color doesn't matter.
Height and depth don't matter.
- Must be a Full Tower size
- Top panel must be removable
- Must be room for a 120mm fan in the top-rear
- Must be room for a 120mm fan in the front as well as below the PSU
- Must be under $150 with or without PSU (I'll be buying a new PSU anyway)
- Must be "single-width", not a "double-wide" or cube
- Front bezel must not be asymetrical or oddly shaped so that a 120mm blowhole would look out of place (I.E., InWin Q500 or Superpower Zephyr KS-101). If the case already has excellent airflow (Such as Antec and Chenbro's models do), this stipulation is null and void.
