I need help
Gosu
i have soyo dragon+ and xp1800 processor
i can overclock i have 384mb kinston 266mhz 2.5
only 140fbs
and i have other pc same memory and xp1700 msi board and i can 148fbs
what happen
i need other memory for soyo
or what
what is beter memory
kinston ddr 266 cas 2.5 chip nynia or transend chip samsung ??
well, you can have two sticks of the same kind of mem that act differently. Just like cpu's. EX. Just because you have 2 1700+ with the same stepping doesn't mean they will overclock to the same speed. 140 is not a bad OC. But just in case, go over all the board settings to try and tweak them however you can. You might want to try it with just one stick of mem. The more sticks you have, the harder it is to OC to a particular point. Good luck.Hope I helped.
