- Aug 12, 2002
- Gettysburg, PA
Ok I have been using KdFold since I started folding but it seems you all use EMIII. So I decided to try it out. I have it all set up and I noticed that it shows the correct number of frames, my score and everything else, but it doesnt show the % until next frame. This sorta makes me mad because I would like to use it.
And another thing, I downloaded the OC.com skin and I unzipped the file and put it in the skin's folder right next to default, but the only skin I have to choose from is default.
