- Nov 7, 2004
I have been using TT fan controler and things were perfect, I then added more fans and decided to get Sunbeam fan controler. the only problem with sunbeam well aside from having very bright leds, is the fans won't start when I have them set at anything less than 7 volts, with the TT they were working fine just for the fact that the TT controler will start at 12 volts for a second then drop to were I have it set at. now with the sunbeam, I have to manually do that everytime I start the PC, I mean I will have to turn the controlers up till the fans start then drop them back down. is there anyway where the sunbeam will do the same thing as the TT controler (start at 12 volts then drop back to where it's set at) capacitors come to my mind here but I am not sure on the how and what . anyhelp please?
thanks
thanks
