Fellow 7VCA owners,
What's your I/O voltage?
Mine is 3.26v when the spec is 3.3v. I believe that this low voltage is preventing me from running my PC133 memory at 133MHz (FSB=100, HCLK+33). I'm wondering if I just have a dud motherboard or if this is normal for this model. If it's normal I'll just live with running my memory at FSB. But if it's not normal, I'll bring the motherboard back to the dealer for an exchange and benefit from the extra performance.
I need your feedback to justify the down-time and the hassle of convincing a dealer that my motherboard is a dud. Please help.
Why I think it's a motherboard problem:
1) I tried 2 different PC133 DIMMs which run fine up to 148 MHz in my Asus A7V / Duron rig - Not the RAM.
2) I/O voltage on the A7V is 3.5v - Not 3.26v!
3) With one DIMM (the Micron - higher quality?) the motherboard can POST with FSB=100 and memory+33 but it's unstable. The other DIMM (generic) no POST at all.
About the rig:
SY-7VCA2 motherboard, Celeron 566E@893 /w 1.80v (using VID pin trick to change default vCore to 1.65), Golden Orb. So far I've had better luck with this board then with an Abit BE6-II (max 873) and an Asus CUBX (max 723).
Soyo SY-7VCA users unite!
-Civilan.
About the rig:
-Civilan.
