Unfortunately, most 120VAC fans don't get good press in the OC groups because they don't represent a Plug-n-Play solution inside most cases. Its a shame too, because they typically deliver better performance for the same form factor than their 12V cousins and often quieter. If the average user has to cut a hole for the AC cord, or put in a relay slaved off the 12V coming on in order to control the 120VAC fan, he/she is often dissuaded from pursuing it. I've got some Rotron 80mm Sprites that put most 80mm 12V fans to shame. Ditto on some Pabst AC fans. I have one 92mm Pabst that is so powerful, it needs a motor start capacitor. It really puts out for an axial fan, yet the noise is very tolerable. It's just a bad image issue. 120VAC kills, 12VDC doesn't. At least not nearly as likely...
Hoot
