- Nov 26, 2004
- France, Lyon
What's up guys ?
It's my first post here, and I think I've found ze place to talk about over-clocking stuff. And it was quite obvious with this web-site's name !
First of all, I wasn't sure where to post this, either in Processors or Memory. Because I believe (or in fact) that what I want to discuss about can linked to both categories.
My system specifications as follows:
CPU: Intel Pentium IV 2.6C 800 Mhz FSB with H-T
Motherboard: ASUS P4P800
Memory: Dual-Channel 2 x 512 Mb Kingston DDR PC-3200
GPU: ATi Radeon 9800 Pro 128 Mb 256-Bit
PSU: Okia 420W ATX
Now that the basic specifications of my system are shown, we can start to discuss. So, the discussion will be based, mostly, on the Motherboard here. Because all I want, pretty much, is to modify the voltage settings from the BIOS features / options.
Please guys, keep in mind that I know how to work around in my Motherboard's BIOS general interface. It's not entirely new to me. The only things I haven't touched nor ever modified are the things I'll discuss here. But already saw those features / options both live in my own BIOS at home (of course) and on pictures on the web, explaining "how to's", but it wasn't clear enough for me.
Of course this is mostly dedicated to anyone who've at least one time changed something in that specific Motherboard, related to manual over-clocking. But of course, anyone experienced enough will be able to deliver facts / comments in this thread's subjects.
And, yes, I've just tried the Search engine, and I did found many, many threads related to ASUS Motherboards, to the P4P800 / Deluxe model(s), to over-clocking, to the PAT / MAM technology. I also found threads with very similar subjects than the ones discussed here.
But...for example, none of the threads I've set eyes and attention in, had their creator's system specifications (when well specified) exactly the same than mine.
So...I decided to create this thread.
Now on the main questions, finally...
Basically, I want to know simple things, that are done in somewhat complex interfaces.
According to my system, specifically, what should I set the settings at, to reach a stable-enough state of over-clocking, from my Motherboard's BIOS (of course) ?
Sure, it's a flat question, and it needs more information, as to what exactly I want to achieve here. Basically I just want to over-clock my CPU, while changing / over-clocking my Memory timings as well. And some other stuff, too. I've learned the names / abbreviations of basic things, during the my epic travel within the abyss of my Search results, which are: CAS - tRP - tRCD - tRAS / vCore - vDIMM - vAGP - Divider - Timings.
These are a few examples. And I'm not posting them just for the heck of it. I know they all got a role upon manual over-cloking. I think I know where to find all those in my BIOS, but I think I'll have to check that out a few times to be sure. But still, I got a good idea already.
What you guys must take into consideration, too, is the fact that, so far, all I've been doing in relation to over-clocking to this day has been to simply use my ASUS P4P800's AI Over-Clocking feature, which does pretty much everything automatically. Such as simply selecting to 'over-clock' the CPU by pre-set %'s, such as 5% - 10% - 20% and 30%.
There's also some features like Memory Acceleration Mode (or well known as the PAT technology) and the Performance Mode.
I've also done some very simple and basic GPU Memory Frequency over-clocking via Rage 3D's Tweak application.
With that said, now the goal is simple. I want to achieve my first manual over-clock, of "them all", which means here AGP-PCI / CPU and Memory (and you can add anything I forgot which could be needed or useful for a successful over-clock).
Again, I'll ask, all that, please, according to my system specifications. I don't want to get examples from higher or lower frequency CPU's or Memory modules. I'm a very visual person...so often I ask for pictures actually showing where do I need to change stuff exactly. But I can usually figure out by myself over time.
Back on the subject at hand...
I must say that, at the moment, my H-T is set to Enabled. And what I mostly use my PC for, is gaming. Recent 3D games, mostly (but not only), which potentially can use a lot of CPU and Memory. So I don't want to over-clock just to get some experience in the domain, I'm doing it to ensure I can get that extra 3% to 10 % performance 'boots', if physically and / or humanly and / or technically possible.
I think I'll shorten this post, and I'll just ask right away...
What are you guys suggesting me to set my Memory timings at ? (i.e 2 - 2 - 2 -5, which means CAS - tRP - tRCD - tRAS in a respective order, I think)
What should I set the vCore - vDIMM - vAGP and Divider at ? (though I don't even think there's anything to change about the 'Divider' at all, but of course I think I'm wrong heh)
Should I disable H-T ?
Should I enable Memory Acceleration Mode ?
Should I enable Performance Mode ?
Also...I've read a lot about 'locking' the AGP / PCI at '33 / 66'. What does that mean more exactly ? Where do I technically change that / those setting(s) in the BIOS ? Why should I change them ? (performance boost ? stability ?) More information on that subject would be appreciated.
About the CPU now, should I set it automatically ? Or manually, along with my Memory settings ? (of course I thinkt the logical answer here is to set stuff manually for the CPU, but I just want to be sure) What should I change the voltage at ? What's the actual name of the settings seen on-screen, in the BIOS, to change the CPU voltage safely ?
I got so many questions, but I fear not many persons actually reached this very line either still alive or not bored. Sorry for the long post !
I'll ask more questions if necessary after the first replies.
But for now on I'll be patient and just wait for facts / comments.
Thanks guys. Thanks to everyone involved in the creation of this web-site / discussion forum. Such a place is a technical marvel !
I got to go now
But...I'll be back ! (of course you need to read this with the voice of the Terminator in mind, mwuhahahaha !)
PSU: Okia 420W ATX
I got to go now
