2 easy ways to find out what moboard you own are open the case..and look around..you will see a company name on their somewhere..or download sisoft sandra and it will tell you the model of your mobo. Now when you find that part out, go to the manufacturer's website and download the latest BIOS. (if you are new to this, go into your bios BEFORE you update it and write down some of the main settings) Also be sure the machine is never turned off somehow during the writing process...or your screwed. OK next, boot up your machine, log into windows...right click and exit all programs besides basic ones on your lower right-hand screen that are unnessesary and disable antivirus if u have it on. Try benchmarking now and see what you get. To OC you go into the bios and up the FSB speed...careful doing this..do it in really small incraments.
