help. tell me what i have to do to put it faster. i dont find nothing about this and how to. i want to overclock the processor and the motherboard too. i hope you ppl answer me. and help.
Whether you can do it or not depends on whether or not your mobo has software BIOS options or hardware jumpers that can enable higher front side bus speeds. Your CPU runs at 6.5 (multiplier) times 66.6MHz (FSB) to attain it's default speed of 433MHz. See if your mobo has the ability to set the FSB at 75MHz instead of 66MHz. That mild overclock would improve performance enough to notice (your memory and everything else will be running faster too), your CPU would then be running at 488MHz, and probably wouldn't require any additional voltage to do so.
