- Jan 28, 2002
- Seattle, but im Estonian
he does cross drilled holes in the blocks so the water doesnt have a defined path through the block. how is that good? or is it just an easy way to make a block?
Lt. Max said:he does cross drilled holes in the blocks so the water doesnt have a defined path through the block. how is that good? or is it just an easy way to make a block?
The water will flow properly through all channels and not take a least path of resistance, such as water flowing in nature, because the water is being forced through the w/b with the waterpump.KingB said:
I would think that the water would take the path of least resistance, therefore more water would flow down a one channel over another. This, in my mind, would cool one section of the block better than another. Correct? This isn't good is it?
That would be due to the head preassure of the waterpump. The higher the water has to lift upward the less flow it will have. IE: A 250 gal/hr pump rated at 4' lift will be a 210gal/hr at a 5' lift.KingB said:I remember building a water pond back when I use to do landscaping for a summer job. We built a water fall with 4 different waterfall points (basically it was 4 water spouts running in a parallel closed sytem with one pump running it). There was a distinct difference in flow rates to the 4 spouts (with the closest spout having alot of flow, while the furthest spout barely had any). We ended up installing two pumps running in separate systems to even the flow to all spouts. Why would this be different? Comment would be appreciated.
Edit: I am not saying water wouldn't flow in all channels, I'm saying each channel will experience a different amount of flow as each channel loop is a different length.
You are not having to deal with the head preassure loss when the lift is 1" so each passage will be really close in flow rate.KingB said:Yeah, I get the headloss component of the waterfall example. That still doesn't compute in my mind the difference in channel loop lengths. I would think to get even flow, each loop would have to occupy an equal volume (As of now they don't). This would mean cross drilling diffent diameter holes.
Does this make any sense or am I out to lunch?
Sorry, but I don't think that is right my friend. First of all, you do get a head preassure loss with height(or how the high the water has to make a vertical climb from the pump). And second, the loss of waterflow due to 90 degree turns or maybe a cross-drilled w/b, is caused by back preassure(restriction).Aesik said:There is no head loss due to height changes, but there are significant head losses due to longer channel lengths and especially due to 90 degree corners or other turns. It all depends on the design of the block.
Correct on the head lossAesik said:. Armed with such knowledge, a person could easily design a cross drilled block that would have the desired flow profile.
