- Sep 15, 2001
A couple of Q's for ya peeps that are water gurus, I want to get my feet wet again, I say again because I have already tried water however the outcome was less then par with my attempt mostly becuase I went cheap and we all know what happens when we go cheap on water.
So I want to try again mostly due to my processor pushing more heat then last time, what I am looking at is a dual radiator set up with VGA and CPU blocks in between and a 1250 Eheim pump, the blocks will be a MCW5002 and either a DD maze four GPU or a MCW50 have not made up my mind yet.
But on the radiators the reason I want dual is because I want to keep my HDD cooling unit intact in the front of the case, because I like the active cooling. Plus I don't see it being a easy task fitting a chevy core in that little space (for reference it is a mid tower Lian-Li case) I want to take two 80mm radiators and attach them to the Blow hole on the top and the back fan under the PSU. Does anyone have any ideas on that concept and how it will work also to keep in mind I have a window and would like to keep it very neat and pretty.
On the setup I would like to make the loop Pump>Rad>CPU>Rad>GPU>Pump.... And hopefully 1/2 inch tubing if it can fit.
I am open to any ideas on anything and I made this thread as a start path to get a idea on where I am going with this, and how much to save up, and my budget is no greater then $300.
TIA
TIA
