Hello,
Second post, first about this system-
DX79SR
i3820
Kingston 9905403-826.A00LF
I have successfully been able to bring the CPU clock up to 4.63ghz (128.61x36) and it runs pretty solid.
No matter what RAM speed or timings I try I can not get my setup to boot much past 4.7ghz.
I have loosened timing, raised voltages, tightened timings, slowed the RAM down, sped the RAM up, let the mobo sort everything automatically, removed all but one stick of RAM... Nothing seems to work.
If I have the bus speed much past 130 it throws a 4F fault and won't even post.
I'm believing this value RAM just does not like to run much faster than that, no matter how far I turn it down. Currently at 4.63ghz the RAM is running at 1372mhz with 12-12-12-31 timing. Default settings are 11-11-11-28.
Does anyone have a few settings I can try?
Thanks
Jeremy
DX79SR
i3820
Thanks
Jeremy
