At 45x with Dynamic Vcore at the last settings i also got a shut down after about 10mins of running prime95, any ideas? what to change?
I switched back to 45x
1.300Vcore and LLC @ Level 5 and the rest where left the same, running prime95 now. At these settings i am reaching an 80C max temp while under full load. Was getting 10C cooler with the other settings but not stable.
should i try backing the Dynamic Vcore down to .060, could it have possibly been getting to much voltage and causing a shutdown?
Ok did as you suggested and seems to be running stable, 30mins of Prime95 and so far so good, temps are looking at 70C max Vcore is at 1.28V and DRAM is at 1.56V
might try for 46x see what temps look like and then maybe 47x
