Warleader165
- Jul 6, 2016
Hello,
I recently overclocked my I5 to 4.2ghz (Using the auto OC on my mobo) and seems to be running fine but.. whenever i changed it seemed to automatically change my voltage to 1.24v (Under load)
I can't find anywhere in my mobo where to set the voltage manually :\... whenever i change the clock speed it sets everything else..
This is my mobo - http://www.newegg.com/Product/Produ...0446076&PID=3821802&SID=iqblly23hz000a1700053
My temps are about 58c - 62c when playing doom and 68c - 74c (hottest core) when using prime95
SPECS -
I5 3570k
Gtx 1070
8GB DDR3 1600mhz
Corsair 750m PSU
- - - Updated - - -
I wanted to know if this was a safe voltage for this clock speed.. or if there was some sort of program i can use to lower it manually.. thanks
SPECS -
I5 3570k
Gtx 1070
8GB DDR3 1600mhz
Corsair 750m PSU
- - - Updated - - -
Hello,
SPECS -
I5 3570k
Gtx 1070
8GB DDR3 1600mhz
Corsair 750m PSU
