i5 3570k showing incorrect cpu turbo speed in BIOS
Mikkee
Hey
So as the title states, im having trouble with my cpu turbo speed. I recently got into overclocking and got to 4.2ghz with stock voltages and it seemed fairly stable. However after opening my case and setting up some fans i booted into bios again and decided to step it up to 4.3ghz. I checked cpu-z and it still showed 4.2ghz. I already tried clearing the cmos and it didn't work. Also realtemp shows 4.2ghz, so i doubt it's a software issue.
Any help please? :/
OptyTrooper
Missouri
Hey
Any help please? :/
If you cleared the BIOS how is it showing 4.2? It should read 3.4GHz.
M
Mikkee
Hey
After i reset cmos it did show the turbo speed of 3.8ghz. I set it to 4.3ghz and booted into windows, but cpu-z still showed 4.2ghz. And just to clarify The oc settings do save in the bios, but im not sure if they are really taking effect. So confused here.
M
Mikkee
Damn this place is awesome
Thanks, i disabled turbo boost and re-enabled it and it showed the correct clock speed again. Thanks alot :D
