Interactivism
- Apr 21, 2020
Hey everyone! Been lurking the forums and finally decided to join!
I got an old Clarkdale i5 650 3.2mhz cpu (with integrated gpu) on a Biostar TH55B HD mobo, no external GPU.
Recently I decided to add some more ram to it, and got two 1866 4gb sticks. Currently the setup has a single 1333 4gb stick (which i want to toss out).
The bios goes up to 1333mhz normal and 2000mhz OC, and I've been trying to OC the CPU to get the new sticks to work, to no avail. I'm definitely new to overclocking, I know my way around a bios and some basics but im struggling to get this to work.
Lately i've been thinking it might be the i5 that just doesn't allow me to get to 1866 sticks. On normal or auto overclock the memory won't work (doesn't even run at 1333, I just get a frozen screen as windows boots up).
The new sticks are both Hyperx HX318C10FB/4 - There is little info on compatibility with my mobo but as far as I've read they should work. I've been testing my OC's only using one (replaced 1333mhz for 1866mhz stick), so that if this doesn't work I can at least return the other one. This is how my mobo reads it:
I started with the 3 step guide from miahallen, some settings are missing from my bios and some things I just can't figure out.
There is also a iGPU Frecuency setting that is present in my bios but not on this image for some reason.
My DRAM Frequency setting will go up to 1333, working on a x10/8/6 multiplier and only going up by increasing the CPU Frecuency Setting. Even if I change the CPU Ratio, it'll still move as x10 / x8 / x6 on the ram frequency settings. I haven't found any separated DRAM ratio setting. I've tried matching the timings to the new ram sticks too.
I've also tried upping the CPU Frecuency to 187, that way I could get 1870mhz on my RAM Frecuency, and lowering the CPU ratio to something like x12/x15/x19 to keep the mhz in control. This didn't work either and I can't figure out how to set the QPI Frecuency and the iGPU Frecuency properly. I haven't dared to mess with the voltages yet.
Any help is vastly appreciated, I know this mobo and chip are olden and it's hard finding info to work with!
