I5 6600k 4.8Ghz OC at 1.3v
Hanns
Hey guys,
Just got myself a new PC and decided to OC it. I was able to reach 4.8ghz on my I5 with 1.3v (Set to manual in bios). Did a couple of tests on Aida 64 seems quite stable. This is my also first overclock, did I just get lucky in silicon lottery or am I doing something monumentally dumb, I'm not sure if I should keep pushing the multiplier?
Attached is screenshot to prove my point
Any advice is greatly appreciated. Thanks! :) OC_results.png
trents
Senior Member
You should run the AIDA stress test for at least 5 hr. to be somewhat confident of stability. If your cooling permits, I would also suggest Prime95 for a couple of hours.
Your total core voltage is 1.328 under load. If it is truly stable at 4.8 ghz you may have voltage room for 4.9.
H
Hanns
Thanks! I'll do that tonight when i'm sleeping. A question, why is my core voltage at 1.328 even though i have set it to be 1.3 on bios?
trents
Senior Member
Likely the LLC (Load Line Calibration) if you have the vcore configured for manual. It's a supplement to keep things stable under load. Not added at idle.
H
Hanns
Hey
I decided to keep pushing the multiplier to see how far i can go. At 5.0ghz i got the blue screen, after increasing the voltage to 1.325 i was able to boot into windows but Aida 64 test failed (No blue-screen,it just said hardware failure detected). So now im stress testing 4.9ghz at 1.3v. Will keep you posted :)
- - - Updated - - -
IMO you did get a good quality silicon, Im able to do [email protected] or something like that.
Do you run it constantly at 1.35v or adaptive? Currently im running it constantly at 1.3v. Is there a reason to go adaptive?
H
Hanns
I ran 4.9ghz stress test on Aida 64 for 2 hours, had work to do so couldnt run it for longer.
dcikes
I guess he's still not done :sn:
I want to try and push it like he did, altough knowing my luck, I'll max out at 4.6 :eh?:
aeriumM
That seems like a really good chip you have there, I have mine at 4.5 and I need 1.35 to run, anything lower it'll bsod
