- Dec 29, 2016
Not sure that cpuid is reading right trents.. look at the hwmonitor ss...the VID(which seeing how that value goes up and down, it's likely vcore) is 1.26V...
Best - what does cpuz say voltage is?
Correction. Total vcore under load with LLC supplement is 1.312.
Your 6600k and mine seem to require the same voltage at 4.5 ghz. Pretty average chips.
Have you tried moving up to 4.6 ghz? Your low temps and modest vcore at 4.5 ghz suggest you may have another notch of overclock in there. I can't get mine completely stable at 4.6 on decent voltage. Core #3 fails.
Cpuid. That was not a typo. The OP posted CPUID not CPUz. Notice it's blue and says aida64 cpuid? Yes I trust cpuz over hwmonitor. But you can't do it blindly! My point was to have him check cpuz to confirm... did I make that more clear?
Cpuz may say the same thing. But since the op never mentioned he enabled LLC, that's a leap to think natural vraise is that much over what he set. It could very well be, but that's an assumption it's enabled. By default on Skylake boards, they are pretty stable from what is set in the bios in my experiences.
