- Aug 14, 2010
- Edinburgh, UK
hello! Just registered here!
got myself a new rig just recently, found this sweet guide and got my cpu clocked to a decent 3.8ghz. And everything would be nice if it wasn't for the rather high (understatement) temps at full load (prime95). What I'm getting is 50C at idle (40-45 if i open my window and let in the amazing Scottish summer air in) and an astounding 99 (sic!) not a minute after starting small FFTs in prime... (90 with the window)
As you can clearly see, that NEEDS to be changed >.>
First off, my config:
CPU: Core i5 760 2.8GHz @ 3.8GHz
Mobo: ASUS p7p55d-e
RAM: Kingston HyperX 4GB (2x2GB) 1600MHz
Cooler: Scythe Mugen 2 rev B. (1 default fan attached)
GPU: Sapphire Radeon HD 5830
PSU: Thermaltake Toughpower XT 775w
in reserve: 2x SUNON 120mm fan, 2x Revoltec Air Guard 92mm fan
and here's the bios settings I used to get here:
I'm rather unsure how to proceed from here on. I could try lowering the voltages a bit and see how low I can get and still be stable, although I'd welcome any and all input regarding that and any other you may want to share I'm rather disinclined to change my cooler (just got it, was told it's good), but I could add the fans mentioned above.
Also, I think the cooler's mounted at least decently. Was getting middle 35-40 in idle on stock. Seems a bit high as I've seen folks getting low 30's with similar air cooling, so maybe I should try remounting it? I'm using a zalman thermal grease btw.
final solution i could just downclock it. but, yeah, I quite like how the 3.8 looks in cpu-z
Mobo: ASUS p7p55d-e
Code:
A1 Overclock Tuner Mode......:[Manual]
Cpu Ratio Setting............:20
Intel(R) SpeedStep(TM) Tech..: [Disabled]
Intel(R) TurboMode Tech......: [Disabled]
Xtreme Phase Full Power Mode.: [Enabled]
BCLK Frequency...............:190
PCIE Frequency...............:103
DRAM Frequency...............: 1,520 (x8 )
QPI Frequency................: [Auto]
CPU Differential Amplitude.........:[Auto]
CPU Clock Skew.....................: [Auto]
CPU Uoltage Mode...................: [Fixed]
Voltage............................: 1.25v
IMC Voltage........................:1.16875v
DRAM Voltage.......................: 1.60v
CPU PLL Voltage....................: 1.80v
PCH Voltaqe........................: [Auto]
DRAM DATA REF Voltage on A.........: [Auto]
DRAM CTRL REF Voltage on A.........: [Auto]
DRAM DATA REF Voltage on B.........: [Auto]
DRAM GIRL REF Voltage on B.........:[Auto]
Load Line Calibration..............:[Auto]
CPU Spread Spectrum................: [Disabled]
PCIE Spread Spectrum................: [Disabled]
CPU Ratio Setting..................: 20
C1E Support........................:[Disabled]
Hardware Prefetcher................: [Enabled]
Adjacent Cache Line Prefetch.......: [Enabled]
Max CPUID Value Limit..............: [Disabled]
Intel (R) Virtualization Tech......: [Disabled]
CPU TM Function....................: [Enabled]
Active Processor Cores.............: [All]
Intel(R) SpeedStep(TI1) Tech.......: [Disabled]
InteI (R) TurboMode Tech..........: [Disabled]
Intel® C-Start Tech................: [Disabled]
