As I said you are overclocking the ram. It is supposed to run at 800Mhz using 10-11/10/10/30 timings, but you have it running at 875Mhz. It could be unstable. If your PC is working, then you are fine, but you should stress test it to confirm. Use the memory stress test in AIDA64 or the "blend" test in Prime95.
