Hello, I have problems with my z68xp-ud3p and i7 3770k.
- The problem is that the PC will freeze up, no bluescreen
- It freezes even after a cmos reset, and setting everything to default settings.
-My ram is HyperX Fury 16GB DDR3 1867 - Tested with 8GB in Each slot - Also tested with Mushkin 4GB DDR3 1333hz
-Tested fixing ram to 1600/1866/1867
-Tested without GPU [GTX670]
-Tested to see if there is any shorting on the motherboard
-Tested without 2TB HDD
-Cooler is H80i - At max load it was ~75deg on Overclock tested with realtemp and prime95
Bios is UEFI U1g
Really going crazy right now - Put everything back with my old asus P8B75-v Everything works...
Any tips ? Thinking about taking it into a shop so that they can test it. Previous owner had a i7-2600K everything was working for him with/without overclocking.
Bios is UEFI U1g
