I just picked up a i7 4790K and have been working on overclocking it. I have a stable (so far, 1 hour stress in AIDA64) running 4.6ghz on all cores at 1.312v.
From what I have researched, 1.312v is a pretty safe voltage level for this chip. However, I thought maybe I could try dropping it down a little bit (although probably won't go much lower) until it is unstable.
Problem is on my motherboard, if I set it to ANYTHING (tried 1.25, 1.3, etc) it automatically ramps up to 1.312v when AIDA64 is running.
I have tried both the adaptive and auto core voltage settings in the BIOS but regardless it still tops out at 1.312v when stressing. I obviously don't want to leave this on override mode as I don't want my voltage constantly running that high.
Any thoughts on this? Thank you guys in advance.
Here are my specs and temperatures I was able to obtain:
Intel i7 4790K @ 4.6ghz (all cores) 1.312v peak.
Cooler Master Hyper 212 EVO / Arctic Silver 5 TP
MSI Z87-G45 Gaming Motherboard (latest BIOS and chipset installed)
8GB (2x4gb) G Skill DDR3 1600 (dual channel, XMP profile enabled)
AIDA64 Stability Test
