Good afternoon. First post here. Long story short, I successfull atempted a stable OC @ 4.8 ghz. Want to know your opinion about my temps, voltage and bios tweaks.
My rig:
4 intake 120mm fans
Cpu coolermaster masterliquid pro 120 with 2 exhaust fans
Intel i7 7700k
Mobo Asus 270z-k
Ddr4 gskill 3400 ghz 1.35v xmp profile enabled ( could only achieve 3200ghz but thats another story)
Msi armor oc edition 1070 gtx with OC @ +120 core clock and +350 memory.
Psu xfx 750w xxx pro edition
So tested stability with that x256 costum changed software to loop as many times as needed to perform a stress test and done firestrike successfull (17125 score) and uningen valley with success too.
Now the interesting stuff. @4.8 ghz cpu, 1.31v core, 1.35v ram 1.15 vccio and 1.15 vsa, power saving things like intel speed, c states etc off, manual OC(not adaptive neither offset), and LLC set to 6 (maximum is 7), I achieved 76 degrees @ stress test, 28-34 at idle, and playing bf1 for 2 or 3 hours 53-65 degrees at cpu and 60-65 gpu degrees.
Opinions? Changes to be made?
By the way, should i increase voltage from 1.35 at RAM to 1.375 or more to get it to 3400ghz or just increase vsa and vcioo?
Thanks in advance and sorry if this is the wrong thread to post..
My rig:
4 intake 120mm fans
Intel i7 7700k
Mobo Asus 270z-k
