Hello, yesterday I chose to delid my CPU and im really happy with the thermal results so far. I have an ASUS IX Formula along with a 7700k on a Kraken X62 but I cannot get a stable 5GHz.
I also have to say I'm new to overclocking so I need a bit of advice. So my problem is the CPU is running at 5GHz, but then drops to 4.7 and then back to 5.0 and so on. Temperature reaches 70°C max under Prime95 load and the voltage is set at 1.300V. Windows power settings are set at High Performance.
Settings I've used in the BIOS:
BLCK = 100.00
Sync all Cores = 50
AVX Instruction Core Ratio Negative Offset = 3
CPU Load-line Calibration = Level 5
CPU Core/Cache Current Limit Max = 255.50
Min. CPU Cache Ratio = 43
Max CPU Cache Ratio = 43
CPU Core/Cache Voltage = 1.300
CPU VCCIO Voltage = 1.2
CPU System Agent Voltage = 1.225
Hope for your help
regards
BLCK = 100.00
Sync all Cores = 50
Hope for your help
regards
